Just been speaking to a neighbor who has recently had a new boiler installed.
For some reason (probably not CPS) they have not used the DP FCU that the old boiler was wired into and instead put a plug on it and used an existing double socket.
Has this been done to avoid having to issue a MWC for wiring into the existing FCU? Would this require a MWC and if so could the have been smart by disconnecting the flex from the boiler and wiring it into the new boiler thus avoiding interfering with an accessory?
Other than being shonky, is there any direct contravention of the BYB by using the plug/socket route.
My thinking is that there are Isolation and Functional Switching facilities local to the boiler and emergency Isolation by means of the DP switch(RCD) in the CU so while not ideal, and not how I would do it, it is not non-compliant.
Fire away......
Fire away......
