Boiler management system | on ElectriciansForums
Discuss Boiler management system in the Green Lounge (Access Only) area at ElectriciansForums.net
I would be asking my local Worcester Bosch rep what he thinks about it. I had a ding-dong with an architect where a Ravenheat boiler with flue gas heat recovery had been specified. Not only are the boilers something I wouldn't go near, the gains from the recovery system are doubtful especially when heating water only. It was so complex as to be laughable. A WB director told me the gains were simply not worth the investment.
It may be the claims being made here are not justified with a brand spanking new boiler.
It's a bit of a bodge, there are far better solutions out there, most modern boiler have the ability to add in proper wether compensation.
Also the bigger question is why is the boiler cycling - it's probably something to do with poor desig or installtion (configuration) of the existing system - better to fix the problem than the sympton.
Book yourself on this course - it's good value, and wll taught: EcoSkies - Courses
RHI for Electricians- Design & Specify Course (Incl. Water Regs, G3 Unvented & 1 RHI Technology)
Reply to Boiler management system in the Green Lounge (Access Only) area at ElectriciansForums.net
