Boiler off lighting circuit? | Page 2 | on ElectriciansForums
Discuss Boiler off lighting circuit? in the UK Electrical Forum area at ElectriciansForums.net
Blackpool,Lancashire.
What is everyone's opinion on taking a combi boiler supply off the lighting circuit? I doubt the boiler would pull more than 300 watts and with all the led lamps being used on the lighting circuit,I doubt it would come to more than a couple of hundred watts.A 3 amp fuse in the boiler spur would be fitted.
This question arises due to the boiler being moved into the loft and the only supply up there is off the lights? If it's not acceptable then please explain why?
I might still have some of the 2 way BC adaptors so you could have light and iron at the same time
Always had one of those in the tool kit.
It had two uses - to temporarily fit 2 x 100 or 150W lamps in a room where I was working, or, combined with a short lead with a 13A trailing socket on one end and a B22 plug on the other, it served to power a drill in pre cordless days, when you only had a couple of holes to drill, and the nearest working socket was some distance away.
No need to go fishing , 90% of houses have an airing cupboard with an old 16a immersion switch , just take a cable from this up the corner of the cupboard to feed the loft
Agree, only thing to watch is it's sometimes on the non RCD side of a split load board, so depending on the purpose the route of new run can matter.
True
If you are fussed you could shift the mcb over to the rcd side if there was a spare ways that is
(I must admit (putting my tin hat firmly on) but on occasion I modify / extend a lighting circuit add a smoke or modify a circuit and don't always move it over to the rcd side when there are no spare ways)
Maybe we should start a confessional thread in the arms...I could certainly contribute, and worse that that!
Tim I hope you aren't admitting to throwing a junction box under the floor or wrapping some connector block in tape up the loft crawl space 😄
Reply to Boiler off lighting circuit? in the UK Electrical Forum area at ElectriciansForums.net
This same scenario popped up on the forum a little while ago. I’d be cautious of the point on the house rfc where you’re trying to get 2x 2.5...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
