Is it okay to spur off a socket on the ring circuit to a boiler spur in 1.5mm?
Discuss Boiler spur in the UK Electrical Forum area at ElectriciansForums.net
Yes, as long as you fuse it down correctlyIs it okay to spur off a socket on the ring circuit to a boiler spur in 1.5mm?
Assuming its oil or gas heating fused down to 3A, why? I'd use 1.5mm FWIW.I'd use 2.5mm to feed the spur.
Because the supply to the heating fcu spurred from the ring will most likely be on a 32a OCPD and I just feel it's the right way to do it.Assuming its oil or gas heating fused down to 3A, why? I'd use 1.5mm FWIW.
Reply to Boiler spur in the UK Electrical Forum area at ElectriciansForums.net
