R
R1nutty
Hi
I recently posted a thread about using a sundial wiring center a plumber supplied for the job.
In the end I thought id use it for an s plan.
everything works fine, valves open and close as should and boiler fires, all ok.
however both the cylinder stat and the room stat call for heat (both honeywell) call for heat when the
time clock is off? Almost like they bypass the clock.I've got my head scratching. Time clock is a horseman h21xl.
any help would be appreciated.
cheers
cheers
