Boiler Wiring | on ElectriciansForums
Discuss Boiler Wiring in the Central Heating Systems area at ElectriciansForums.net
I have had a new boiler fitted today. One of the cables used is a 3 core and earth. They have put a red sleeve on the CPC and used that as one of the cables. Is that allowed? I thought all cable runs had to have a connected cpc.
No that is not allowed because the cpc is not insulated. The only material surrounding the cpc is the outer sheath of the cable which is not designed or intended to be electrical insulation.
Also, although it won't affect this scenario, the earth core is often smaller than the live cores.
Strictly a green/yellow insulated conductor forming part of a multicore cable may be oversleeved and used as a live, but most people consider it bad practice.
Reply to Boiler Wiring in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
The point is that you set up a schedule of what temperature you want at what time and the nest brings the heating on at the right time to achieve...
davesparks
