Bollard with G24D-3 lampholder - can I fit a G24D-2 bulb? | on ElectriciansForums
Discuss Bollard with G24D-3 lampholder - can I fit a G24D-2 bulb? in the Australia area at ElectriciansForums.net
ringer
Peterborough
Am looking at a job to fit an additional bollard to an existing set of three. Have identified the bollard here but this has a lampholder for 26W G24D-3. The existing bollards have G24D-2 lampholders with 18W/840 bulbs. Can I fit an 18W bulb into the G24D-3 lampholder in the new bollard, or will I run into problems because the lampholder and driver will be expecting to run a 26W bulb?
The lamps won't fit directly into the wrong lampholder as you will find the plastic tabs won't align properly. I have known these tabs to be cut of the lamps to let them fit though.
Reply to Bollard with G24D-3 lampholder - can I fit a G24D-2 bulb? in the Australia area at ElectriciansForums.net
Great! Thanks so much for your help. I’ll have a dig around that site and others and see what I can find :) Cheers
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
