- Joined
- Dec 28, 2008
- Messages
- 36
- Reaction score
- 5
I need to replace a wooden shower cubicle with a bath. From what I understand, If I get a steel (not plastic) bath, I need to get the bath equipotentially bonded with other metal in the bathroom. The only metal existing is the copper pipes that supply the basin and toilet fill. These have safety earth clamps on them in the cellar and are earthed back to the consumer unit.
I have read the posts already on this forum about this topic and there seems to be far too many different opinions for me to be sure about what work is specified so I hope you can staightforwardly clear this up for me.
It would help if someone could explain why this bonding is necessary although several ideas spring to mind, please correct the following if my understandig is wrong:
1. Metals must be earthed in case they somehow contact a live wire and would electrocute someone who touched a live metal bath. e.g. someone uses an extension lead to bring a hairdryer into the bathroom and drops it into a full bath and then grabs hold of the bath. The earth connection causes a current in excess of the rated fuse of the circuit with the hairdryer on to will trip the switch on/blow fuse on the consumer unit switching off the live voltage and saving the person from death.
2. Static charges can build up on insulated metalic objects causing differences in potential so if someone touches 2 objects with diferent potential they get a shock (but not usually life threatening?)
I read that all circuits in the bathroom must be bonded together e.g. the light, the shower plus the metal objects. Is this done by running a wire from the earth on the light fitting to the earth on the shower pull cord and then to the copper pipe and then the bath? Or do I just need to put an earth clamp on the copper pipe and attach an earth wire from that to the bath? If the circuits for the shower and light and the copper pipe are earthed onto the consumer unit then they must be at the same 0v earth potential right? Therefore there will be no potential difference between those earths and also the any live voltage coming into contact with an earthed part will flow to earth and blow a fuse. If this is so why is it necessary to run extra bonding wires between earth terminals of the circuits and the pipe and the bath aswell? Could bonding the bath to the wrong thing be dangerous? e.g. workmen dig up road and live wire contacts with water main, copper pipe is then live and so is bath? Surely the earth link back to the consumer unit will be the shortest path?
Also, I noted that the shower circuit and the lighting cicuit (which is for the whole house) only have mcbs but no rcd. Is it simply a matter of replacing each mcb with an rcbo of the correct value and I can forget about the bonding?
Which parts of this job need part p? I am hoping the answers will be very straight forward at least so that I am confident to ask an electrician for exactly what needs doing as I will just be using the yellow pages and won't know them from adam.
thanks
thanks
