bonding cert | on ElectriciansForums
Discuss bonding cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
shagg
Hi guys just a quick post what cert do you use when just upgrading the main bonds from a 6mm to 10mm :confused:
Are you with a scheme? If so give them a call, they will give you the info.:D
Just had a look and Upgrading the Main Equipotential Bonding would require a Minor Works!
as far as i am aware anyone can upgrade bonding conductors and is non notifiable, aint got regs at hand but that was always my understanding
Thanx's gents for all the reply's. I think it's a bit of a grey area most of spark i know issue different cert from one another thinking there right due to different Niceic inspectors telling them so :rolleyes:. I think we need a bit more of a clear view on this matter:(
Reply to bonding cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
We wouldn't be at all surprised I have been a QS for 25 odd years.
