When running a new feed in armour, that will also require a bonding conductor over the same run, is there a problem with buying armour with an extra core and using one of those? I only ask as I've only ever seen a separate green and yellow zip tied to the side of the armour, if you're using 2 cores and the sheath as your earth, why not buy 3 core and use the other core as your bond?
I suppose it's meant to be unbroken and it would be rare in commercial setups that the armour going in is running from the MET right to where the services come in at the other end
