Bonding conductor | on ElectriciansForums
Discuss Bonding conductor in the UK Electrical Forum area at ElectriciansForums.net
Midlands
Im doing some alterations in part of a school. I noticed a water stop cock that has no bonding conductor. Its not the main stop cock as that is another part of the school. I carried out an R2 from the local sub board i am working from and got 0.32.
Am required to bond it to bring it within the 0.05 requirement or is it ok with the main bond at the main stop cock? I would just do it but its a bit of a job so if its not required then i will leave it...
Cheers
0.05 requirement
There is no requirement for a main protective bonding conductor to have a resistance not exceeding 0.05 Ohms. A low resistance (e.g. not exceeding 0.05 Ohms) is between the clamp and what it is connected to in order to ensure that there is an adequate connection.
thanks for pointing that out. so many guys erroneously have this silly figure of 0.05ohms as the max. resistance of a bonding conductor.
Indeed. Would be curious as to which Reg. they believe requires it! Only mentioned in GN3 (in the context mentioned above) as far as I am aware.
sadly a case of reading things wrong. for a long time, many sparks thought it was not done to extend pme to a garage/shed and so spent hours banging in useless short thin rods.
estimate the length of the bonding conductor. look up the resistance/m for the csa then you can guesstimate what it should be.
just wondering what mary whitehouse has to do with it ( she wanted to stop cock)
I was always taught that to guesstimate what the resistance should be on a bonding conductor is 0.05 ohms per meter so on a reading of 0.32ohms your run should be roughly 6.5m.
However like said said previous I think you should check if this could bring an earth potential otherwise you should be fine.
Reply to Bonding conductor in the UK Electrical Forum area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
