bonding for landlord | on ElectriciansForums
Discuss bonding for landlord in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
carried out eicr for landlord
no main bonding to gas and water mains
c2 coded
told them we need to run 10mm from main board to each area
the gas is pretty much non accessible , is there anything within the regs or guidance notes that states what to do in tyhe case i.e bond at different point etc ?
thought so guys , thanks same house there is a new board fitted around 2-3 years ago going by labeling , circuits labelled ring 1 ,2, kitchen ring
no ring continuity on these circuits , pretty strange to have 3 rings given these readings any advice on what to do from here
i plan on checking every socket for connections ,r1+r2 tests, but failing that im thinking they may not be done on rings
new board installed 2 - 3 years ago and no bonding to water or gas .... say's it all
got one better , main switch is rcd (non compliant) and had a 2.5 cable doubled up with the main tails , i changed it and gave it its own breaker it tripped rcd , who ever done bored change thought this was a good way to bypass rcd to stop the tripping
Reply to bonding for landlord in the UK Electrical Forum area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
