zap
I'm working at a friend’s place and trying to keep costs down so here goes...
The gas meter is external and it feeds a boiler under the bungalow. (built on a hill).
The boiler ignition is fed via class II accessories and there is no prospect (I think) of an earth fault posing a threat.
There is no gas supply within the dwelling i.e. living areas.
The water supply is bonded to the met and tests satisfactory.
Does the gas service still require bonding? and if so, why.
Any help will be hugely appreciated.
