Bonding Location | on ElectriciansForums
Discuss Bonding Location in the Australia area at ElectriciansForums.net
Smugley
Just wondering if there is a consensus on this or if it is another divided issue.
When selecting a location to main bond say the incoming water pipe, you need to be within 600mm of entry to the building, but the clamp must be accessible for inspection. Sometimes I choose one or the other requirements to take precedence. For example in Victorian terraces where typically the water supply enters under the front steps and runs at ground level and pops up in the rear kitchen. Do you bond within 600mm of the pipe's entrance into the building structure, under the front doormat, making the clamp difficult to get to, or bond when the pipe enters the living space? Couldn't guarantee this won't be after any t-joints which may be there now or be added in future.
It doesn't have to be 600mm from entry. It says something like "or if not possible as near as is practicable" ......
where practicable the connection to the gas, water, ect service should be within 600mm of the service meter, or at the point of entry to the building if the serive meter is external and must be on the consumers side before any branch pipework and after any insulating section in the service
Yeah, clear as mud! Heh heh! Thanks for the comments. It's as I suspected, still a difficult question. I think it's safe to say it would be unlikely anyone would branch off the water supply before the main stopcock, so in the case I have in mind I will go for under the kitchen sink. Last one I did was easy - access panel put in specially by builders under the front door mat.
Here's one for you all to consider:
The water main is 25mm plastic (Alkathene) and enters the building vertically through the concrete floor of the utility room.
It rises approx. 300mm from the floor & is then fitted with a brass stoptap. From the stoptap, it rises in 22mm copper into the ceiling void - a length of a cople of metres max, - where it is attached to 22mm plastic pipe.
This plastic pipe runs to all the taps, boiler & other water outlets in the house.
The question is; does the vertical run of 22mm copper pipe need to be bonded?
my honest opinion!!
NO!!! you would be inducing a path to that little piece of copper thats fitted and INCREASING The likely hood of a shock!
my honest opinion!!
That's what I thought, but I asked the question at the college where I was taking the 17th Edition course and half the class of 20 said "yes" & the other said "no".
The lecturer said "no" & when he went off for his coffee break he asked the other lecturers and again, the opinion was divided.
Thats the answer. And only way to know for sure is to test it (IR tester, Meg Ohms, other end to known earth, if greater than 0.02M Ohms or 20,000 Ohms, no bonding required. If less, yes bond it)
Many thanks for that. :)
In the event, I fitted the bonding clamp to the pipe & ran the 10mm yellow/green cable from the MET to it but left it disconnected from the clamp on the pipe.
When the inspector arrived to complete the EIC, I explained to him that the copper pipe was connected to plastic at both ends & asked him if he wanted the bond connected or not. Without any testing as you describe, he said he did so I connected it.
Reply to Bonding Location in the Australia area at ElectriciansForums.net
