Bonding main water PVC | on ElectriciansForums
Discuss Bonding main water PVC in the UK Electrical Forum area at ElectriciansForums.net
tylers green
Hi all,
In a bit of a quandary,main water incomer is PVC ,from stop cock in property all copper.
Now,do I bond the copper or not,read OSS and it only says recommends bonding to copper,I've been on other forums and had mixed replys,50% say yes,50% say no.
Any thoughts?
Official line is....if the incoming service is plastic but the internal installation is all metallic, bonding is "recommended" unless the test as SS has described above, proves that the internal pipework does not meet the definition of an extraneous-conductive-part.
Is this in the regs Lenny ? Not a trick BTW a genuine one I have GN8 on order so maybe it's in there but I can't find it in the BGB
ATB J
Reply to Bonding main water PVC in the UK Electrical Forum area at ElectriciansForums.net
C
Noisy main cold water pipe, my plumber hasn't heard this before. Hi Folks, Would like to cast the net far and wide to try and get some resolution...
ComfortablyNumb
C
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
