Bonding on a rewire | on ElectriciansForums
Discuss Bonding on a rewire in the Australia area at ElectriciansForums.net
I
IRB
When rewiring a dwelling and installing a 17th ed board what bonding is required, main bonding, gas and water, supplementary? thanks
Sure it's been asked many times, plastic supply pipe, stop cock under the floor, around a metre of copper then multiple plastic fittings etc etc. I'm not gonna install Main Bond to the water service, anyone think I should? Clearly I've done the gas.
No point, no potential is being introduced into the property.
Sent from my GT-I9100 using Tapatalk
Reply to Bonding on a rewire in the Australia area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
I like your way of thinking.
loz2754
L
