Bonding Stainless Steel Tables In A Kitchen | on ElectriciansForums
Discuss Bonding Stainless Steel Tables In A Kitchen in the UK Electrical Forum area at ElectriciansForums.net
B
bluecallum
Wiring for a new kitchen,client is having all new stainless steel tables,have these all got to be bonded.If yes what size earth cable do you suggest.
Regards
Ok,thats brilliant,wonder why that's not required.
By bonding everything together there is a chance that a small fault will be transfered across a larger area, you are in a way creating a Conducting Location. Ensure small appliances are protected by way of 30ma rcds.
Would they be classed as an extraneous conductive part?
No this is an old argument and I blame the 15th Edition and some consultants who still think putting green/yellow wires on any metalwork is a good idea. It some cases it could prove to be lethal.
I agree but was trying to get the OP to think why they may or may not require bonding as the post I quoted of the OP's said "wonder why that's not required".
We recently had this problem in a commercial Kitchen. NIC say not necessary if they have rubber/plastic feet. Therefore not in contact with earth. Maybe advise them to get some ? In our case they all had ferrules on the feet so no problem.
They are not likely to be in contact with earth anyway, most commercial kitchens have electrically insulating floors, not bare soil.
Reply to Bonding Stainless Steel Tables In A Kitchen in the UK Electrical Forum area at ElectriciansForums.net
A crimping tool that is designed for copper terminals, may well not put enough pressure on the terminal to hold the cable correctly if used with...
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
