Bonding SWA | on ElectriciansForums
Discuss Bonding SWA in the Australia area at ElectriciansForums.net
H
hyperliteliam
Evening..
Is it always necessary to bond the steel wired on SWA? Cause say for example from a metal DB to a metal clad socket or isolator, as the metal DB is earthed and the SWA is glanded up to the board then the steel outer will be earthed... right??
Cheers
Reply to Bonding SWA in the Australia area at ElectriciansForums.net
Sounds more positive.
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
