B
baldsparkies
When bonding to gas 10mm seems to be the norm these days. I came across a pme install with a 60 amp cut out and 16mm tails with 10mm main cpc. The bond was in 6mm with R2 well under 0.5 ohms. So I ask the question, should this be upgraded to 10mm or will 6mm suffice, and if so why?
Would be interested in your thoughts guys,
