B
bluecallum
Hi am i reading it right that before you carry out any electrical work out in domestic properties that these pipes have to be upgraded to 10mm earthing cable even if they are already bonded but in less then 10mm
Discuss Bonding to gas and water pipes regs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
No.Hi am i reading it right that before you carry out any electrical work out in domestic properties that these pipes have to be upgraded to 10mm earthing cable even if they are already bonded but in less then 10mm
Reply to Bonding to gas and water pipes regs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
