A
aaelectric
Went to look at a cu change first inspected the gas and water bonding,
lathe meter for gas is 2 floors down and no access the pipe that comes into the house goes under the floor to the boiler. There is no access to fuse board I could not find main water looked under sink and all is boxed in. War would you do. Of the continuity test was under the 0.05 would you say it's ok
