M
mattcos1972
Afternoon all.
Having to bond the water and gas supply on the CU change I am doing. No pipework has ever been bonded and I cant seem to find any way to the water inlet (at the kitchen at the back of the house) from the CU which is in the middle of the house, backing on to the outside wall. The kitchen floor is tiled and there's units over every inch of the place.
On the plus side the gas metre is in a cupboard about 2 meters away from the MET! Yay!!
The only solution I can think of is to take the cable outside the house and to run it along the outer wall round to the kitchen and into the back of the kitchen cupboards and onto the inlet pipe. The customer is happy with this set up, but is there any requirement for the cable to be run in conduit or trunking or can it be clipped to the wall directly?
Obviously conduit is a bit bulkier than a 10mm cable which after a coat of sandtex will melt into the side of the house, pretty much unnoticed.
Has anyone come across a similar problem? Any ideas / suggestions would be much appreciated as always.
Thanks again in advance.
Matt
Matt
