keniff
Hi, could someone point me in the right direction, iv read somewhere that if an extraneous conductive part reading is above a certain resistance it should be bonded, where can I find info on this? Thanks in advance
Discuss Bonding water and gas in the Australia area at ElectriciansForums.net
Hi Keith, Safely isolate the installation. Temporary disconnect any main bonding cables (gas, water e.t.c.) from the MET for the duration of the test to remove their parallel earth paths if it's considered necessary. With a high resistance ohmmeter set on M Ohms @500V, connect one lead to the MET and the other lead to the "extraneous conductive part". If the meter reading is 0.022M Ohms (22K Ohms) or greater, NO supplementary bonding is required. This is based on a 10mA let-go threshold that I use. The NICEIC alternatively quote =>7K Ohms (6667 Ohms calculated) based on a 30mA let-go threshold. See link below for further details:
http://www.electriciansforums.net/e...ical-regulations/16558-extraneous-yes-no.html
Hi Mark top answer as usual mate, but I noticed you used the term High Resitance Ohm meter in connection with an Insulation Resistance tester.
We had a thread on here a while back where a lad came on and was told by his tutor to use your term for it, and I think, me included shot the tutor down in flames as we all regarded it as a wrong term.
When someone like you mate uses it, makes me think , has the term now been put into the GN books?
Thanks very much for the replies, so is there a formula for this then? You say calculation would I find this in the regs book? Thanks again
Reply to Bonding water and gas in the Australia area at ElectriciansForums.net
