M
MBEINST
Hi Guys
I am about to undertake a consumer unit change and having looked at the bonding already in existence in the property I don't think that any further bonding is required.
I am fitting a new consumer unit fully populated with RCBO's and there is sufficient 10mm bonding to the incoming cold water supply and incoming gas supply which are both in the garage. As far as I am concerned this meets current regulations.
The old fella in the property is adamant that I need to bond the hot and cold water pipes, and metal sink in the kitchen and the radiator in the bathroom?
I only qualified two years ago and would like to be put on the straight and narrow if I'm missing something.
