dnjr
Dear All
I expect this is going to raise a few eyebrows but..
I know that is your unsure about an earth bond to a water main you can do a continuity test and look for a figure under 0.05 ohms.
I have also read that you can do an IR test, under 23K ohms needs bonding and over 23K does not
Now the thick bit
surely 0.05 is under 23K so why does it not need bonding
when do you use the continuity test and when the IR test
When Ive asked other sparks they just say it is so accept it ( which in other words means they dont know why)
I dont like to just do it because... can anyone put it in simple terms for me
Thanks and regards
dnjr
Now the thick bit
Thanks and regards
dnjr
