bonding | on ElectriciansForums
Discuss bonding in the Australia area at ElectriciansForums.net
GPack
Two quick ones please.
Main water incoming service is plastic. I take it we don't need a main bonding conductor going to it?
Main gas box is in the garage and pipe disappears under concrete. Don't know wear it enters the building. There is a gas fire, gas cooker and gas boiler. Which bit should I take my main bonding conductor to?
1 Why would you think that ?
2 The nearest accessable point of entry before any branches
If they are multiple,then all of them
Reply to bonding in the Australia area at ElectriciansForums.net
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
