switched on
Hi i am doing a property atm a periodic and its got 6mm bonding obviously it needs 10mm but does it need upgrading i think it will be a code 3 etc iand cross bonding between the boiler pipes?, and if it has 16mm tails instead of 25mm on 100A fuse but i cant replace these without concerning the dno. Thanks for your advice just didn't know how far i should go with this
