Bonding | on ElectriciansForums
Discuss Bonding in the Australia area at ElectriciansForums.net
Just been to view a property that wants a straight forward c/u change, gas is bonded as its next to the c/u, water is not.
Do i have to bond it or can i put it on the cert as a recommendation?? The main water tap is at the other side of the property and would involve taking out kitchen cupboards, taking up wood flooring etc, making the job bigger than the customer wants.
I think the answer is yes it has to be bonded but what are your thoughts??
Thanks.
You've already answered your question. But remember the clause 'as near as practicable'.
Can you use other copper water pipes as an earth conductor? ie. bond to the hot if its near the CU and then cross bond from the hot to the cold under the sink - only works though if the hot is all copper (no plastic inserts).
Its actually got to be less that 22K, but I round it up to 25K
Based on the resistance of a person being 1K, if they touch a live part path and extraneous part resistance would be 22K + 1K
10mA current is 'safe', 230V/23000 = 10mA
Anything above 25K would result in current <10mA
oh ok makes sense now
i was thinking of
do i need supplementary ie where if you have blah blah and the resistance is less than 1667 or more than 2 M ohm then you dont need it ( something like that )
If the pipework installation is copper throughout then it should still be bonded, even if the supply to the property is PVC.
I ALWAYS upgrade main bonds when changing a CU.
Never had resistance from the customer yet.
why would they complain if its the lifesaver in electrical but what would you do if floors and cupboards wernt to be touched, could you run it along the soffit or eves of houses?? or would you go about it??
As Ian said really.
Once explained, then you can talk through with the customer costs and best route to take.
In some cases, they are happy with either black or white conduit at low level outside.
Reply to Bonding in the Australia area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
