booklet cables | on ElectriciansForums
Discuss booklet cables in the Australia area at ElectriciansForums.net
A
amit
Hi all, As part of my coursework please can anyone please tell me all cables sizes that are classed as “booklet cables”
You help would be much appreciated
Many thanks
1mm. lighting circuits altough 1-5 is now normally used
1-5, lighting ciruits
2.5 20 amp radial circuits ie immersion, hand dryers, also use in heavily loaded lighting circuits or long run lighting circuits, also used for ring main circuits
4-0 larger ring main circuts, 32 amp radial circuits that arent too long
6-0 cooker circuits, some shower circuits
10-0 shower circuits usually above say 8 Kwatt or on longer runs,
16-0 small sub main circuits,
dont forget that this is nowhere near exhaustive. as long as the cable is matched to the circuit breaker there is now reason to apply cables to most loads. I have done lighting circuits in 6-0mm before due to the length of run
Reply to booklet cables in the Australia area at ElectriciansForums.net
Here are photos of the power supply unit, somebody told me I need a new transformer? Many thanks in advance.
more the merroir, if not good for me - good for others on here :-)
