Hello, I am a 17 yr old lad who wants to become an electrician.
I am interested in become an apprentice.
I have been unsuccessful with getting into an apprenticeship so in the meantime, what courses do you recommend I enroll in? Free or paid, I don't necessarily mind. I can ask for funding if it's that expensive.
Are there any books that you recommend? I know about Lessons in Industrial Instrumentation but I don't know if UK electricians rate it.
TL;DR
17 yrs old
In the meantime while looking for an apprenticeship. What courses and books do you recommend? free or paid, doesn't concern me.
Its not an amazon book, but easy to get it from them, it has practical articles C&G exam examples with model answers.
A book on inspection and testing might be better at some point in the future. OP is starting out and probably would benefit most from a grounding in basic theory, installation practices and regulations - testing won't be particularly engaging without knowing what it is you're testing.
Upvote 0
It's not 'optimistic', Mike. OP is a 17yo wanting to start in the industry and likely has limited funds to spend on reading material.
Might as well jump straight into industrial design for all the sense anyone would make of inspection and testing as a starting point.
Upvote 0
Try and be a bit more proactive and give some advice instead of just criticising my posts. the OP has got start somewhere, what would you recommend that's not the dry BS?
Upvote 0
You use the exact same descriptor as I did in this post prior to one from yourself.
Upvote 0
Thing is, Mike, I'm currently getting towards the end of an apprenticeship. As far as I'm aware you're not, and never have been, an electrician. That's not intended to belittle, but something I consider to be a valid point where providing advice to a prospective apprentice is concerned.
While testing and inspection is an important subject for all electricians, I don't believe its study will be of much use to the OP at this point and I make that statement with some standing on the subject.
If you disagree by all means put forth your position, but posting daft insults isn't condusive to meaningful discussion, doesn't help the OP and most certainly isn't a viable face saving measure (if that's the reason you resort to it).
Upvote 0
It was not meant as an insult daft or not, its intent was to try and defuse what looked to be an ongoing possible future conflict.
Upvote 0
The best thing to do isn’t buy a book but watch videos by GSH Electrical (for the practical side) and Joe Robinson (for the theoretical side).
You should get all the training material you will need for each of the units you are doing. If you are only 17 I’m guessing you will be going full time either doing a C&G level 1 (7202) or level 2 (8202) or even a T-level if your local college is doing them. If you are doing level 2 the only book you will need is the On-Site guide BS 7671:2018+A2:2022 (make sure it is brown) as your exam will require you to look up tables and do calculations off the tabulated data and its worth getting familiar with this book before hand.
If you are going to do the course privately at your age you won’t get funding on an accelerated course and will have to pay for it. However if you are doing it privately the course will probably be 2365 L2 or similar as private providers can run the courses (exams) as they like so they can have multiple start dates over the year.
You are starting your training at an awkward time as the Government are pulling funding for under 19’s for all electrical courses bar the T-Level as they want to prove they work. Hopefully this gives you a bit of information. I’ve only put the course codes so you can look up anything that might give you a better insight of what you might be doing.
If you aren’t doing an apprenticeship or T-Level 3 you must complete a Level 2 Diploma before doing a Level 3 diploma. Then once you have the L3 diploma/T-Level you have to find a company willing to hire you as a (Trainee Electrician (Stage 3) while you then do the L3 NVQ 2357-44, AM2 and 18th edition to get your Gold card. As a non apprentice you probably won’t get any funding for the NVQ, AM2 or 18th Edition either.
Upvote 0
|Reading
United Kingdom
Other
If other, please explain
I am currently looking to be an electrician but I haven't been accepted into an apprenticeship yet.
Books and courses for an aspiring electrician?
Electrician Courses : Electrical Quals
yung_kio,
David1977m,
Electrical Courses
