Boost Button | on ElectriciansForums
Discuss Boost Button in the Central Heating Systems area at ElectriciansForums.net
mhar
devon
Big long house, some of it used for guests. We are looking for the facility to have a 1 hour boost button for the central heating located somewhere in the guest area.
Obviously I am aware of the boost facility available on many programmers. However customer does not want the guests to be able to control the entire ch & hw system, we just want them to be able to give the heating a 1 hour boost.
Something commercially available would be good, otherwise we would have to go along the route of a retractable switch to trigger a timer module which may have to operate a relay.
Ideas (and solutions!) welcome please
Could be done with an E30 or similar.
Wired in parallel with the programmer:
L & N taken from incoming side of prog,
SW L taken back to outward side of prog.
Could also be taken from the wiring centre if that suits. There might be a neater solution.
That's the sort of thing I am after, thanks
Is this a seperate heating zone and how do they controll the tempurature ?
At the moment there are no zones, something that is being addressed in the coming months. This is why we are looking at a simple boost button to fulfil a short term need.
Reply to Boost Button in the Central Heating Systems area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
