Boosted 7.5kw shower? | on ElectriciansForums
Discuss Boosted 7.5kw shower? in the UK Electrical Forum area at ElectriciansForums.net
Scotland
Hi, i am wondering if anyone has any experience with a 7.5-8kw shower that has a pump or some sort of boost internally fitted? Working at a hotel and there is a 9.5kw shower on a 6mm cable quite a distance from the c/u and with insulation likely on top as the isolator switch was melted. I recommended downrating the shower to 7.5 or 8kw to help with this problem and prevent it happening again.
I recently installed a mira sport 10.8kw boost shower at a property with poor pressure and found it to be quite effective. I am wondering if anyone knows of a 7.5/8kw shower with something similar inside to boost things/.
Reply to Boosted 7.5kw shower? in the UK Electrical Forum area at ElectriciansForums.net
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
