Booster Pump Needs Reset Daily Hi,
I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank.
Normally the pump would stop working only when there is no water in the water tank. But, recently for the past week, in the middle of the night, the pump would stop working even though the water tank is full. All I need is to reset the pump manually, but it is annoying as it is located at the top of the house.
What could be the cause of it? Could it be caused by a slow leak after the pump thus it cannot detect the loss in pressure?
Henry
Homewoner
Booster Pump Needs Reset Daily to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Henry
Homewoner
