L
Leah
So my first solo job after my assessment turned out to be fun. The customer's plasterer had removed light fittings and switches a pretty much everything had come loose, after much head scratching I realised that the live from the downstairs had been borrowed in the hall switch (I'm assuming because whoever wired it didn't have 3 core on the van that day), this would have been easy to spot if everything had been terminated but with it all out it took me a while.
Anyway with that done could someone advise me on what recommendations I should be giving the customer, is it just that they should where possible make anyone working on these circuits aware of this and that if they upgrade the board (which they are planning to do in the future) then this with throw the RCD's - is there anything else I'm missing.
Obviously I'm hoping to get the job to fit a new CU, should this happen and I right in just quoting to re-wire the 2 way with 3 core rather than putting both circuits on the same RCD?
