Borrowed neutral | on ElectriciansForums
Discuss Borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
J
johninleeds
I'm trying to install a spur off an existing lighting circuit.
I thought I would be able to replace a single switch with a double and use the new switch for the spur.
However the builder hasn't brought the Neutral down to the switch, it's up in the ceiling and I can't access it, the floor above is tiled.
I've seen references to "borrowed neutral" and I can probably pick up a neutral from a ring circuit used for tumble drier/washing machine
Is this allowed and will there be any problems back at the fuse box??
Alternatively are there any "trick of the trade" that will sort out this problem??
Many thanks
The fact that you're talking about borrowing a neutral shows a lack of knowledge mate, the "trick of the trade" would therefore be to consult an electrician locally who can come and give you an idea of how little this would cost you.
Hmm, second thoughts maybe i should delete my prior comment.
I'll replace it with this....OP, if you have access to the ring, then the solution is very obvious. Borrowing a neutral is a non-starter, terrible practice and against regs. If you have any knowledge of the regs, then look at 314.1 and you'll see it doesn't comply - borrowing a neutral can be lethal.
Reply to Borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Thanks very much for your help chaps. It turned out to be reversed polarity and some dodgy DIY stuff. I'll go back another day to sort it...
