Borrowed neutral | Page 3 | on ElectriciansForums
Discuss Borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
J
johninleeds
I'm trying to install a spur off an existing lighting circuit.
I thought I would be able to replace a single switch with a double and use the new switch for the spur.
However the builder hasn't brought the Neutral down to the switch, it's up in the ceiling and I can't access it, the floor above is tiled.
I've seen references to "borrowed neutral" and I can probably pick up a neutral from a ring circuit used for tumble drier/washing machine
Is this allowed and will there be any problems back at the fuse box??
Alternatively are there any "trick of the trade" that will sort out this problem??
Many thanks
why would it not work?
a typical reason please stroppy..
and code for a shared neutral on an ECR please...
I see what mood glenn is in haha.
C2 every day of the week glenn.
And it would work, just potentially dangerous - unless it was a 17th ed board and the interconnected circuits were on different RCD's.
Now, calm your passions glenn :p
Ok to start with it is against the regs as has been pointed out, then if the line and neutral are on different RCD's they won't hold as they will be out of balance. And non-technically it doesn't make much sens.
Code? Umm, C2 I would think?
I can honestly say that I posted my answer before I saw Mark's anwer. And I thought C2 then cheated slightly by looking it up which took extra time. By that time he had posted!
As an apprentice I would have no shame in admitting I don't know something.
Until I came on here I didn't know borrowed neutrals existed, so I've learnt something!
Reply to Borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Thanks very much for your help chaps. It turned out to be reversed polarity and some dodgy DIY stuff. I'll go back another day to sort it...
