Borrowed Neutrals ! (gotta be careful) | on ElectriciansForums
Discuss Borrowed Neutrals ! (gotta be careful) in the UK Electrical Forum area at ElectriciansForums.net
muzza1
london
Hi Lads, how are you all? Was just wondering if any you have come across "the hidden killer" (borrowed neutrals)? Thought it would be a good idea just to raise awareness. Thanx.
I had one on some three phase. Had 3 banks of lights all 240v, isolated the bank I was changing fitting on. Went up ladder tested for dead all seemed good. As I disconnected the neutrals one side touched my thumb one my finger, lights went out then was fed via my hand. Shock of my life muscles froze, slowly fell back off the ladder, ended with third degree burns on 2 fingers and a few grazes from falling. Lucky escape.
Blimey, that sounds like a nasty one! Note to self, test again ! and again...
If you make anyone aware of this that wasn't before and they claim to be electricians then they are kidding themselves IMHO ... its part of your college work and can be a killer if you didn't pay attention.... for all the other out there that receive a nasty supprise this way then thats why we spend yrs learning how to do our trade safely , treat every circuit that you haven't wired yourself --- though it may have a borrowed Neutral and work accordingly and you wont fall foul of this set-up.
To true, Darkwood. I can't remember covering this in college. Even if it makes just one youngun stop and think before he chops (and grabs) it's well worth chatting about. Just reiterating the need to stop and think, only for a minute. could well save a nasty shock.
I always give Neutrals a wide birth regardless unless ive persoally designed and wired the circuit ... too many DIY jobs out there it isn't just a case of domestic crossover of stairwell lighting...
You can really only get a shock if you complete a circuit with your body, best way to work is to pretend every cable is live when you make them off this way you never touch the conductors thus greatly reduce the risk of finding a borrowed neutral its not just a case of borrowed neutrals but N/E faults, poor earthing systems etc can create a hazard voltage on a multiple cable joint even if you follow correct isolation procedures....
Its ironic that all the emphasis is to test/test again before working on a circuit but little is taught to make you aware of the fact you break a circuit open at say a joint it can create a voltage that wasn't there to start with due to unrelated conditions.
Had one on a school some years ago,fitted a new rcd board which tripped occassionally turned out to be a neutral on the wrong bar,so came up with this test to find it,leave rcd to that side of board off and using a tester pull each neutral in turn until offending one is found.This was fine as I soon found one that was "live",returned this to correct side of board thinking happy days job done,I then touched the "dead" neutral bar and received a right belt which caused me to fall off the ladder,turned out there were 2 crossed neutrals feeding lights in store rooms that were only used occasionally.Hell of a way to learn a lesson that was.
Reply to Borrowed Neutrals ! (gotta be careful) in the UK Electrical Forum area at ElectriciansForums.net
True. Although I'd hazard a guess that things like woodworm treatment are probably chemically quite similar? Don't know.
Brilliant thank you so much for your help 😊 x
