Wonder what’s peoples thoughts on this, upstairs lighting has no cpc throughout, 2 bedrooms on ground floor on same circuit have cpcs. Cables are wired using joint box method, Found joint box for upstairs lights with cpcs cut away, reterminated this joint box but still not getting a cpc on the circuit. Must be another joint box somewhere but unable to find it as lofts been converted. Client doesn’t want the upheaval of rewiring, there’s a socket local to the joint box. Would taking a 4mm from that socket to the joint box be okay? From what I’ve read I don’t see there being an reg against it.
