Bosch Oven doesn't want to play | on ElectriciansForums
Discuss Bosch Oven doesn't want to play in the Electrical Appliances Forum area at ElectriciansForums.net
Milton Keynes
I took the fan motor off a working Bosch built in electric oven to replace it, and now the heating element does not switch on, though if I switch the mains cooker wall switch I can hear a relay click in the control panel, so there is power going to it. The only two contacts I touched were the motor feeds, I'm mystified, and have no volt meter on site, I would think the oven would work without the fan motor connected ?
What can I check ?
I had an oven the other week that needed the clock setting first and then after that had to press the select button for approx 5 seconds before it came on. Can't remember the brand, and I thought it was knacked at first until the householder came to the rescue!
Castle Wilko power goes off about once a month. Eventually even the mere male has had to diagnose and fix the "broken" oven. Wifey, well aware, just laughed :) .
What can I check ?
do what i do, fob it off onto the appliance engineer, the time spent tinkering could be better spent elsewhere
I had to go on YouTube in the service station when I picked my van up because I didn’t know how to open the filler cap!
You know what? - it feels better now I’ve share that!
Reply to Bosch Oven doesn't want to play in the Electrical Appliances Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Oh I see. I will check that one as well. Thank you!
