Braking Time Neutral Distributed vs Neutral Not Distributed | on ElectriciansForums
Discuss Braking Time Neutral Distributed vs Neutral Not Distributed in the UK Electrical Forum area at ElectriciansForums.net
Cookie
Earth
Can anyone tell me what this pertains to?
[ElectriciansForums.net] Braking Time Neutral Distributed vs Neutral Not Distributed
And why does it reference table 41.1?
A quick look at the paper mentions these two cases under IT systems:
When the neutral is not distributed (three-phase three-wire distribution), the following condition must be satisfied
When the neutral is distributed (three-phase four-wire distribution and single phase distribution), the following condition must be satisfied
Alright. So why would the neutral make a difference on disconnection times?
I suspect that should be breaking time, not braking time.
I can't see how having a neutral or not would affect the required braking time.
I noticed that as well. Perhaps a translation fail. 127/220Y is used in South America.
Anyone have the latest copy of IEC60364 who can confirm whether or not such a table exists in the IEC? Author talks of table 41.1 and table 48.
Reply to Braking Time Neutral Distributed vs Neutral Not Distributed in the UK Electrical Forum area at ElectriciansForums.net
Here in the UK the "floating neutral" (also known as an IT supply from Isolé-Terre) is typically seen on small generators, up to a couple of kVA...
