T
T0M0
Hi All,
Just done a PIR and could do with help with a couple of codes.
3 dual sockets are all branched from CU. There is a 2.5mm T&E from 16A breaker to junction box below CU. Each socket is then wired directly to this JB. If they were on a radial it would not be a problem but does the branching cause a problem? If so what code? I’m tempted to code 3.
Upstairs light switches are missing backboxes! Switches screwed into plaster lats. Code 2?
Loft lights and switches are missing earth (snipped off). Class 2 equip so code 3?
Any help appreciated and thanks for reading.
T0M0
T0M0
