Brand new tap timer leaks around collar Per the pics attached, I have a brand new tap timer fitted to my outdoor tap with a brand new washer. It always leaks from the bottom of the fitting collar. I have tried four different washers (all pictured), both individually and in combination. I have tried tightening the connection, loosening the connection, applying lots of PTFE-tape, applying a little PTFE-tape, applying no-PTFE tape.. always the same leak. Any suggestions? Most online advice relates the the washers: should I try to source a different type of washer perhaps?
Brand new tap timer leaks around collar to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
