U
united4ever
My Electricity breaker keeps tripping about 8 times a day:mad: It also happens in the middle of the night when we are sleeping, happens when we are out so times when we are not using electricity. Usually just a case of flicking up the breaker switch however this morning the switch wouldn't stay up (instantly switched down to off position) so for about 2 hours we had no electricity. Unplugged everything and kept trying to turn it on. After about 2 hours it stayed on though there was no obvious reason why.:confused:
Had a mate look at it who is a retired sparky - he tried isolating it and read the currents of the wires going into the breaker which were normal he said. Couldn't really solve it but thought it might be the breaker switch itself. Said to keep an eye on it and he could order a replacement switch.
Anyway, any experts got an idea what could be causing this? Also, if I want to get a professional in to sort it how does it work - do they come and give a quote to solve the problem no matter how long it takes or do they agree to work on it and charge by the hour until it's done. I'd like to know how much it will cost upfront and want it sorting once and for all.....but the guy who came round today spent an hour trying to isolate the problem and I can imagine a lot of it is elimination and head scratching - don't want to pay hundreds and then the electrician fob me off with some non solution.
I live in a 2 bed new build flat (4 years old). We don't use excessive amounts of electricity.
Thanks in advance
Is it a MCB or RCD (or RCBO) that trips?
If you don't know the difference, post a pic of it :-)
How an investigation will be charged is really between you and the sparkie. I'd charge an hourly rate as it is very hard to say up front how long it will take and I don't like working for free. ;)
The thing about an intermittent fault is that it isnt always there, so no matter how much testing you do you wont find it if it isnt there. The best thing you could do is wait until the breaker wont reset meaning the fault is still there. Does it trip at certain times i.e when the water heater is on?
What type of breaker 6-10-16-20-32-40Amps or the main RCD breaker ? plus is it lights.power, ? a picture would be nice and as for not wanting to spend 100s on an electrician well all the jobs like this i go to is around £50-£70
Yes we need to know the type of CU set up, you can pull all the plugs you want but if you have a Neutral fault you will need to start pulling those out of the CU..NOT a job for a DIYER,,Get a Pro in
Have professional registered spark do a EICR report.
He will then be able to tell you whats wrong.
From what you say I assume it an RCD thats tripping.
He will then need to trace/rectify the circuit with the earth fault, which could take time.
The line "I don’t want to spend" seals it for me!
Expert advice costs money but probably not as much as you think!
Stick with you’re mate, he’ll be cheap, useless but cheap.
Siemens RCCB breaker, Also says next to the switch 80amps and has written 5SM13 317-0. The lights still work when it trips. Will post a picture tomorrow.
HANG ON HERE!!!!!!!!!!!!!!!!!! is the guy who had a look BOB,DAVE,JIM FROM THE PUB BIG LOL:19:
This type of fault could take 10 minutes to find or up to several hours and still not be conclusive.
What may help the diagnosis is a record of what you are/were doing when the fault occurs.
Where in the UK are you?
What? This is just a fault that with the correct test equipment should be relatively simple to find.
[/COLOR]
What if the EICR doesn't pick up the fault?
If your test results for the fixed installation are within spec, then there is no possible reason that a healthy RCd will trip.
Unless there is an obvious wiring fault in the CU.
Or a faulty appliance being plugged in, a time clock or thermostat turning a faulty appliance on. The list is endless a fault won't always be present on a circuit which is why a EICR may achieve nothing. But the RCCB keeps tripping even though a report says there is nothing wrong with the installation.
but however you label it, as Rich.250 said the circuit affected need identifying and testing, along with the RCCB. If the standard tests show a problem then great, if not then you need to look further.
Now all the OP needs is a spark who knows what he is doing ;)
btw. a question for the OP - does it trip more when (or after) a lot of rain and do you have any outside sockets or lights? Or perhaps a bath or sink that has leaked recently?
In a four year old flat ?
Its probably a split load CCU installed under the 16th ed. when the electrical design for the flats were put forward.
There are about four or five possibilities it could be.
Try this one for starters.
Switch off the dish washer/ washing machine at the local switched fused control unit. This will determine whether or not you need an electrician or an appliance technician.
Not disputing that, it was in reference to the idea of getting a EICR carried out to find the fault.
Electricians do not scratch there heads,we are well trained to carry out all manner of works including fault finding and repair/replace parts where neccessary,that sort of fault maybe found witihin 10 mins or may take 2 hours.personally i would offer a customer the opportunity to have 2 hours at a fixed price to find the fault and repair(parts at extra cost),and in the unlikely event that not found/repaired then discuss the way they want to proceed.£50-60 labour.Retired sparky may not have the appropriate test equiptment anymore.
If this is a neutral to earth fault and the FCUs are single pole then this strategy may well be no help at all.
If an RCD has been tripping that frequently then it's probably on it's way out through over-use and needs to be replaced regardless. Some basic tests are needed here, but also is experience and judgement to interpret the results. And that's something I charge for. Fairly, but charged none the less.
Breaker keeps Tripping
united4ever,
Rockingit,
