W
whazza22
Hi everyone,
I'm sure this topic has been risen plenty of times.
I'm a qualified electrician and I am going to replace a consumer unit for a relative. I am not registered with NICEIC or NAPIT so will be getting it tested by the council.
Can anyone explain the procedure for removing the main fuse as it is sealed?
I know it will never be checked but would just like to know what everyone does. It's absolutely crazy that a qualified electrician is meant to call western power to remove the seal or replace the seal, especially if they have a business to run!!
Thanks in advance.
Sorry for the wrong number, I know I have a lot to learn still that's why I'm here.
The point was you can die changing a light just as easily as messing with a main fuse in the wrong circumstances.
You can die falling off a ladder changing the lamp. It's all a matter of priority and using common sense and, of course, a little experience comes into play.
thats more like it, the thing is there are quite a few of us on here with over 3 times your level of experience,and due to the way things are going with this forum at the minute we are getting tired of the diy brigade coming on here pretending to be sparkies.just think for a minute before you post and it will help you to avoid getting leapt on by a bunch of irate sparkies,the way its going we tend to judge you by your posts not by what you say is your level of experience.
I would add that not only should you think for a minute, but maybe you should check what you've typed before you post it - just to make sure you've not missed-out an "0" here & there. ;)
nail hit on head. 3 days to 3 weeks notice to send a man out for less than 1 hour. that might have been acceptable in 1930, but it sure ain't these days. bet if it's a new boiler with £1000 profit, they'd be a bit sharper.
i have to admit to 1 case of personal injury pulling a DNO fuse. the bugger was that tight, i tugged like frick, it came out suddenly and i fell backwards on my arse straight onto a 3036 fuse holder pins. bloody painful.
Breaking Main Fuse Seal..
whazza22,
telectrix,
