British Gas Meter Bonding | on ElectriciansForums
Discuss British Gas Meter Bonding in the UK Electrical Forum area at ElectriciansForums.net
SW. London
Just been looking at a family members house and electrics; about 2 years ago the Gas Board moved their meter from under the stairs to a box outside. Anyhow they have not run any bonding to the meters new position and have bonded onto a gas pipe not far the original meter position, which is where the CU still is.
Tried calling them this morning and theyre saying they dont know who installed it because it was 2 years ago. Anyhow after being put on hold for 15 mins i hung up. Anyone else ever come across this ?
not as bad as one i came across. instead of bonding the pipe where it entered the building at 12ft.high, they ran the 10mm out with the pipe, then 10m draped across the house wall, no clips anywhere, to the external meter box.
Within 600mm isn't it supposed to be?
British Gas. If you haven't been kept waiting for hours, had multiple attempts over many months to get the simplest of things sorted, been given so much bull shxt to cause a world shortage, been invoiced when you have no relationship with them, you are doing exceptionally well.
You are lucky to have had such a mild experience with them, your dealings with them are very likely to get a lot worse
Thats reassuring, thought they would send round that bloke on the adverts with the solar powered van/spacerocket :flagstick:
A bit like this ... x4 :D
[ElectriciansForums.net] British Gas Meter Bonding
At least all 4 are consistent.
The 600mm guidance is from the point of entry of the gas pipe into the premises (and before any junctions in the pipe) not where the meter is.
How far from the point of entry is this bonding?
At least it's visible if it's near the C.U
Reply to British Gas Meter Bonding in the UK Electrical Forum area at ElectriciansForums.net
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
J
Have my water pipes been plumbed the wrong way? Good morning, I recently had an extension, new bathroom and new en-suite fitted. Prior to the...
jennys07
J
Gas cylinders are usually connected via rubber hose. But large plastic tanks would be through steel pipe, maybe underground. Go figure
6K
You can splice at the first or second ground rod but you will need an extra tear drop or acorn for a 5/8 ground rod. You are allowed only on wire...
