Broken core 2 way switch | on ElectriciansForums
Discuss Broken core 2 way switch in the UK Electrical Forum area at ElectriciansForums.net
Essex
Afternoon,
I've just been to a new build finishing off some lighting and found a fault in the 3c&e between the landing and hallway. No continuity on 1 core.
It's going to cause a lot of damage to replace the cable. The other 2 cores & CPC are good, IR tests fine.
Is there anything out there wireless, everything I have seen looks to still need the 3 cores between switches.
Suggestions welcome!!
Afternoon,
How old is the property? is it still under warranty?
Reply to Broken core 2 way switch in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
