G
Geostar1865
Hi gents, advice please
new conversion, in bedroom newly decorated
hi wiring was carried out about 4 years ago but this part of the house has just been finished.
we have two 5A sockets for table lamps either side of where the bed will be.
also have to wire in/connect the wiring for 2-way switching but f
before I did this checked to sockets were working and found not to be, they are switched from the bedroom lights switches (triple switch).
The sockets did not work.
Disconnected wiring and checked continuity, found live (brown) had none, cut back as far as I dare and still no continuity.
Dont want to have to rip off newly installed and varnished skirting or rip up floorboards or walling.
i know it's not good practice, however is it possible to use the neutral as the live feed ( suitably sleeved with the correct colour) and the other earth as the neutral ( again sleeved). Earthing of the two sockets carried out by running a cable from the 5A socket not the earth of an ajecent 13A socket.
The two lamps that will be plugged in will be using 7w or lower led lamps.
Other ideas gladly accepted..
