O
Octopus
Hi all, I'm new here and looking for some pointers as to how to approach a "problem" I encountered on Friday.
My work entailed adding 2 new fused spurs for outside lights on a house. All was going really well until I got high readings on the earth loop test.
After some more tests I established that the R1 and Rn on the ring are good but the R2/cpc has no continuity.
More head scratching and I've established that a spur was added to connect a cooker hood (many years ago) and the "broken" connection is in this "leg" of the ring circuit.
The problem is that the the "connection" which is believed to be faulty is not accessable, and the home owner doesn't want me to pull up the new hardwood flooring they've put down.
I've established that would be possible to "add" a cpc link between the two "known" ends of the circuit so that the CPC continuity is restored - in this solution the R1 and Rn would use the "old" cable.
Is this an acceptable fix?
Or do I need to upset them by ripping up their flooring to gain access the the junction box?
Or can I leave the house "as is" with the fault and complete my MWC with high values on the earth looop?
Thanks for your help.
