Broken switch on night storage heater - fixable?! | on ElectriciansForums
Discuss Broken switch on night storage heater - fixable?! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
The General
Well, firstly I ought to say that I think it's a broken switch!
I've checked that power is getting to the switch, but when you turn the dial and it 'clicks' there is still no power output in the returning line down to the elements.
I can't see what else it could be? Open to offers though...
So,
Customer has asked me to fix it if possible.
Is it possible?
I must make it clear that I'm not an electronics engineer and I'm pretty new to the whole domestic installation game, so soldering/intricate fiddly wiring is not for me. However, if you can buy a straight drop-in replacement then I ought to be able to cope!
It's a Dimplex model XL12N if that helps.
If it's not possible the customer has got a couple of old heaters that are gathering rust in the shed, so they want me to replace it, but I'd hate to go through all that work if I can just drop a new switch into the existing one (particularly as I don't even know if the other ones work!!)
any suggestions?
thanks in advance!
probably....... it's an obsolete model, sir. no spares available, but we can supply you with a nice shiny new model for ÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁ
So you assume that the switch is faulty but it sounds like you didn't test it and you didn't check the full circuit out and check the over temperature device hasn't operated then.
I sense that phrase is going to be used soon
hence why I'm seeking advice from more experienced people on a forum like this!
over temperature device? - pray tell me more......
I checked that power was coming in up to the incoming terminal of switch, but once operated there was no output on the return terminal back to the element - so perhaps naively I have assumed that the switch is dodgy?
Dimplex were actually very helpful in providing part number etc, so a new Thermostat & Cut-out assembly can be on it's way to me easily enough if that is the problem.
So, enlighten me:
How to actually 'test' the switch itself? I can see the mechanical operation is working and the contacts are being made, so what else do I need to look for? genuinely, I'm all ears! :bigear:
Continuity - isolate the supply, then check continuity through the switch. I take it you have test equipment?
yup.
But surely if there was continuity through the switch then there'd be a voltage at the outgoing terminal?!?
unless you mean measuring continuity across two other points - I'd assumed you meant across the incoming/outgoings terminals...
I am suggesting that you do a dead test on the switch to check the resistance between the incoming terminal and the outgoing terminal on the switch. So far you have only done a live test for voltage. Check for resistance and operate the switch to confirm the switch is actually switching the circuit on/off.
This is pretty rudimentary stuff. Are you sure that you are competent enough to be working as an electrician?
Perhaps not, but at least I'm smart enough to know when to ask for help rather than just bodging a job and hoping for the best!
The only way to learn is to ask questions, and it is becoming clearer every day that the course I did had quite a lot of gaps in it.....
I'm doing my best to plug those gaps as quickly as possible, but learning on the job is part of that process!
anyway, back to the matter in hand..
I'm still not sure that I understand why measuring the resistance across the switch will tell me anything different to what I already know?!
Surely if there was even a hint of continuity then when a voltage is applied there would be some sort of output?
Feel free to tell me to go back to school, but my understanding is that even if there is a high resistance there'd be some sort of current?
I just don't see what measuring the continuity across the switch is going to tell me that I don't already know? The circuit is not being completed within the switch, because if it was then there'd be an outgoing voltage....
unless of course I've got completely the wrong end of the stick, which is entirely possible.
You need to do something really basic and not make assumptions
Why work live when most of the problems can be located with the appropriate test equipment when the equipment is dead
You need to understand that most heating appliances have over temperature devices fitted these can be fusible thermal links or resettable bi-metal switches that disconnect the power to the elements until they are manually reset
Thank you.
The Dimplex website mentions a thermal cut-out, but simply says to contact Customer Service (read 'sales'!) line...
Do you know how to check if that is the problem, and if so, how to reset them?
Or do I have to go through Dimplex?
Not sure from memory the heater model you have but I think the over temp cut out is located close to the charge control it's a bit awkward to get at but is easily recognised if you know what you are looking for
its item no 4 thermal cut out
[ElectriciansForums.net] Broken switch on night storage heater - fixable?!
Reply to Broken switch on night storage heater - fixable?! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am a landlord/owner of a flat. I am just about to spur off nearby sockets to provide the additional 24hr supply to new Dimplex Quantum storage...
