Hi
I've got a Nest outdoor camera. I don't have an outdoor socket so need to run the cable indoors to a wall socket.
The end of the cable has a weatherproof USB plug which is just under an inch in diameter and can't be removed. The cable itself is much narrower.
So basically I need to drill a near 1 inch hole through the wall but don't want a gaping hole around the cable and the wind blowing in. I've seen brush faceplates that might be a tidy solution but wondered if anyone else had a better suggestion?
